Oracle Database Backups
1 post • Page 1 of 1
eivanovic
Post by eivanovic »
Oracle Database Backups are necessary to avoid data loss in case of a database crash.
For Linux a variety of ksh, sh or bash scripts can be found in Internet. ( google, oracle support etc.)
Here you get a robust script how to deal with RMAN Backups by executing a .bat file.
Put this in a .bat file - ( full_backup.bat for example )
This .bat file generates an oracle rman command file for a full database backup on the fly and executes it on the Oracle server.
All logs and command files have a certain timestamp. Please follow the instructions in the file to setup the directory structure according to your
Server Layout.
Test the file manually before you implement it in your Windows scheduler.
@ECHO OFF
:: file : backup.cmd
:: description : run rman backup to disk
:: Author: Christof Prettner
:: Version: 0.1
:: History
:: Version + Date + Author + Updates
:: 0.1 | 28.03.2017| Christof Prettner | Initial
:: 0.2 | 28.03.2017| Christof Prettner | Set Date Time properly, added rundatetime into CMDFILE
:: First: date and time setting (RUNDATETIME)
:: According to your local Server please change the following parameters before first execution.
:: RUNDIR - the location where the RMAN command file will be stored
:: LOGDIR - the location where to store the logfiles of the Database Backup
:: ORACLE_HOME - the Location of the Oracle Binaries
:: ORACLE_BASE - the root Directory of the Oracle Installation
:: BACKUPDIR - the location where snapshotcontrolfile, controlfileautobackups and the backup controlfile to trace will be stored
set arg1=%1
for /F %%a in (' wmic os get LocalDateTime^| findstr ^[0-9]') do (set datetime=%%a)
set RUNDATETIME=%datetime:~0,8%-%datetime:~8,4%
:: Configuration
:: (you may simply replace this with parameters of course)
set ORACLE_SID=%arg1%
:: rundir==> where the rman-commandfile will be build and run.
:: you must have write-permission to that directory!
set RUNDIR=D:\\ORACLE\\scripts
set LOGDIR=D:\\ORACLE\\scripts\\log
set ORACLE_HOME=D:\\app\\oracle\\product\\12.2.0.1\\db1
set ORACLE_BASE=D:\\app\\oracle
set PATH=%ORACLE_HOME%\\bin;%PATH%
set NLS_DATE_FORMAT="DD-MM-YY HH24:MI:SS"
set BACKUPDIR=D:\\Oracle\\backup
set LOGFILE=%LOGDIR%\\%ORACLE_SID%_%RUNDATETIME%.log
set ADDR=’job@jobacle.at
set TMPLOG=%LOGDIR%\\tmplog.$$
:: Cleaning up of old logfiles will be done in another program
:: Build de rman-commandfile
set CMDFILE=%RUNDIR%\\%ORACLE_SID%_%RUNDATETIME%.rman
echo run { > %CMDFILE%
echo CONFIGURE RETENTION POLICY TO REDUNDANCY 2; >> %CMDFILE%
echo CONFIGURE BACKUP OPTIMIZATION ON; >> %CMDFILE%
echo CONFIGURE DEFAULT DEVICE TYPE TO DISK; >> %CMDFILE%
echo CONFIGURE CONTROLFILE AUTOBACKUP ON; >> %CMDFILE%
echo CONFIGURE CONTROLFILE AUTOBACKUP FORMAT FOR DEVICE TYPE DISK TO '%BACKUPDIR%\\ora_cf%%F'; >> %CMDFILE%
echo CONFIGURE DEVICE TYPE DISK PARALLELISM 2; >> %CMDFILE%
echo CONFIGURE DATAFILE BACKUP COPIES FOR DEVICE TYPE DISK TO 1; >> %CMDFILE%
echo CONFIGURE ARCHIVELOG BACKUP COPIES FOR DEVICE TYPE DISK TO 1; >> %CMDFILE%
echo CONFIGURE MAXSETSIZE TO UNLIMITED; >> %CMDFILE%
echo CONFIGURE SNAPSHOT CONTROLFILE NAME TO '%BACKUPDIR%\\snapcf_%ORACLE_SID%_%RUNDATETIME%.f'; >> %CMDFILE%
:: explicitly names the format in the allocate channel
echo SHOW ALL; >> %CMDFILE%
echo sql "alter system archive log current"; >> %CMDFILE%
echo DELETE FORCE NOPROMPT ARCHIVELOG ALL COMPLETED BEFORE 'sysdate-1'; >> %CMDFILE%
echo BACKUP AS COMPRESSED BACKUPSET INCREMENTAL LEVEL=0 DATABASE INCLUDE CURRENT CONTROLFILE PLUS ARCHIVELOG; >> %CMDFILE%
:: echo sql "alter database backup controlfile to trace as "%BACKUPDIR%\\ctrlfile_%ORACLE_SID%_%RUNDATETIME%""; >> %CMDFILE%
echo CROSSCHECK BACKUP; >> %CMDFILE%
echo REPORT OBSOLETE; >> %CMDFILE%
echo DELETE FORCE NOPROMPT OBSOLETE; >> %CMDFILE%
:: RMAN don’t like the following in the run-command apparently…
:: echo LIST BACKUP OF DATABASE; >> %CMDFILE%
:: echo LIST BACKUP OF ARCHIVELOG ALL; >> %CMDFILE%
:: echo LIST BACKUP; >> %CMDFILE%
echo } >> %CMDFILE%
:: End of Command File Generation
echo Starting the script > %LOGFILE%
%ORACLE_HOME%\\bin\\rman target / cmdfile=%CMDFILE% msglog=%TMPLOG% >>%LOGFILE%
:: merge the two logfiles
type %TMPLOG% >> %LOGFILE%
echo Starting backup controlfile to trace > %LOGFILE%
echo alter database backup controlfile to trace as 'D:\\oracle\\backup\\controlbackup_%RUNDATETIME%.bkp'; | sqlplus / as sysdba >> %LOGFILE%
:: checking for errors
::findstr /i "RMAN-06273" %LOG% >> %LOGFILE%
https://www.winccoa.com/fileadmin/image ... backup.txt
