I'm trying to discover BACnet devices over different subnets, Delta (DSM-RTR) and Notifier BACnet Gateway-3, each of these devices has slaves controllers under the MS/TP network, I don't have BBMD hardware and I don't want to use it as I'm using direct discovery method !.
I tested this method over WinCC OA with johnson controllers (NAE/NCE) and I was able to discover it successfully (Only the router controller).
Is it possible to discover the MS/TP devices through (delta/notifier routers) in WinCC OA using this method ? is this method supported in WinCC OA 3.16 ?. If yes, please share the settings, if no what other options do we have rather than BBMD hardware to discover devices ?
The config file entries are not changed in my test. and on the BACnet driver config: Address binding was static and IP for BACnet router was inserted, network ID remains 1, and port is 47808.
check attached image, please
Thanks
