We are just updating a system from 3.8 to 3.16.
In the Alert Screeen we had the Time Format "DD.MM.YYYY HH.MM.SS.mmm"
This was achieved by using the Format "%c" and checking "Millisecs" in the Columns Properties Page for Columns "timeStr" and "ackTime".
In 3.16 the "Millisecs" Checkbox is not present.
Leaving the Format String empty as proposed by the Online Help displays the time as "YYYY.MM.DD HH:MM:SS.mmm".
I_m looking for ideas to get the old format in 3.16.
Alerts Screen Time Format
Re: Alerts Screen Time Format
The option to display milliseconds in the AEScreen can only be used if no "user defined" format is used.
When looking at the documentation you can find a hint for this limitation.
If no format is defined and the option to display milliseconds is used the following format is used: "YYYY.MM.DD hh.mm.ss.ms"
