Hi Everyone,
I have a panel (I will call main) with an embedded module inside, where I open panels larger in size than the embedded module.
What I want is to pinch (zoom in/out with two fingers) the panels inside the embedded module, but the only I get is zoom in/out the main panel.
I am missing something but I don't know what. ¿Could you help me please?
I am working in Windows 10 with version 3.15 P007
Thanks a lot!
Marc
Pinching in an Embedded Module
Re: Pinching in an Embedded Module
I tested it with an embedded module but the described behaviour did not occur.
Only the panel inside the embedded module was zoomed.
The test was made with the Mobile-UI running at an iPad.
On which device did you start the UI?
marcvelarodino
The device is a laptop with touchscreen (Dell inspiron 13) and Windows 10.
I have tested it on a touch screen monitor.
During the test we have seen that sometimes "zoom to pinch" is made for the outside modules and not only for the embedded one.
The problem was reported to our development department with low priority.
If the panel which has the embedded module is loaded in another embedded module, e.g. as panel in the main area when using one of the panel topology templates, it is working correctly.
marcvelarodino
I have more information on this topic.
If I try to pinch in the embedded module slowly (I mean the normal way) the zoom is applied to the main panel.
If I perform a quick and short pinch, then the zoom is only applied to the embedde module.
On the other hand, I found that if I configure the two finger panel navigation (panelGridMode), then the other gestures (zoom and panning) doesn't work at all.
¿Is it the expected behaviour?
Marc
Marc
Hi guys,
It's possible to stop the base panels from zoom in & out when pinching by setting the "size", "Maximum Size" & "Minimum Size" all to the same x and y values. Apply this rule to the all static Embedded Modules.
At least this is working for me with a SIMATIC IPC277E multi touch.
My problems start when trying to limit the zoom factor applied when pinching!!!
The help files describe how to use the mouse wheel to change the zoom factor. This method can be easily adjusted to limit the zoom factor.
But I couldn't find any information about how to limit the zoom factor when pinching?
Thank you
Nuno
Thank you
Nuno
set the module to not zoomable via setScaleStyle(SCALE_NONE)
Hi Martin,
Thanks for your reply. Let me explain in more detail my issue.
I have set my global zoom factor limits in the config file:
minZoomFactor = 0.5
maxZoomFactor = 5
These limits are OK to the majority of my panels. But I have one specific panel where I need to limit my zoom factor window to interval [0.5, 2].
When using the mouse wheel to apply zoom I can easily achieve this using the following code in Wheel event script:
main(mapping event){
float minFactor, maxFactor, f;
getZoomRange(minFactor, maxFactor);
getZoomFactor(f);
float factor = (event.angleDelta.y / 120.0) * 1.1;
if ( factor > 0.0 ){
if (f< 2) panelZoomIn(myModuleName(), factor, event.localPos);
else{
if (f> 0.5) panelZoomOut(myModuleName(), -factor, event.localPos);
Is there a method to achieve similar results with pinching?
Thank you
Nuno
minZoomFactor = 0.5
maxZoomFactor = 5
getZoomFactor(f);
else{
Thank you
Nuno
I see. Sorry to say, but you can not set the limits via script.
I put this on our feature wish list
