case insensitive query
8 posts • Page 1 of 1
m.sabitov
Post by m.sabitov »
Hi
How i can do case insensitive query with LIKE operator?
Re: case insensitive query
can you please describe in detail which query you want to use.
Which part of the query shall be checked case insensitive?
m.sabitov
Post by m.sabitov »
SELECT ALERT '_alert_hdl.._text' FROM '*' WHERE '_alert_hdl.._text' LIKE "*Valve*" its work for "Valve", but not work for "valve" of "VALVE"
thalter
Post by thalter »
this should work
SELECT ALERT '_alert_hdl.._text' FROM '*' WHERE '_alert_hdl.._text' LIKE "*[v,V][a,A][l,L][v,V][e,E]*"
m.sabitov
Post by m.sabitov »
maybe, but only for one word, i needed solutions for any words
thalter
Post by thalter »
If the SELECT is in a script you could convert the Search-Text with a function
string convertText(string p_filterText)
  string r_wert;
  int i, i2, L1;
  L1=strlen(p_filterText);
  for(i=1;i
Internally "LIKE" uses patternMatch(), however there is no way to tell it to ignore the case while comparing.
So: you can't
m.sabitov
Post by m.sabitov »
Thank you Thomas, its good idea!
Martin you can think about implementing keyword UPPER and LOWER in wincc queri, its will very useful
