I am looking for guidance on setting up user authentication in WinCC OA using Azure Active Directory based Single Sign-On (SSO) and/or Multi-Factor Authentication (MFA) for system access.
Any help, documentation, or experience would be really appreciated!
Thanks & Regards,
Dhaval Abotiyawala
Azure AD SSO/MFA for WinCC OA Authentication
- hpuchegger
Re: Azure AD SSO/MFA for WinCC OA Authentication
Did you already check our documentation as well as the possibility of our 'WinCC OA AI Assistant' regarding User Administration?
https://www.winccoa.com/documentation/W ... asics.html
Br, Herbert
Br, Herbert
Also check the roadmap as it mentions MFA and Azure Entity ID. Although not all mentioned features will be delivered with 3.21.
