I have a question regarding the NGA with PostgreSQL and segment switching.
( WinCC 3.20 P003)
I wanted to see how the segments work in NGA with PostgreSQL so I created a simple project for testing.
Legacy Standard Project, Single Server, SQLite, NGA with PostgreSQL
Problem steps:
1. I created an archive group with segment duration 2 hours. Added some datapoints and made some value changes so the segment gets created.
2. Directly after this I changed the segment duration to 1 hour.
3. The segment still showed the old duration of 2 hours and also did not automatically switch the segment after 1 hour (actually expected this).
4. Tried to manually switch the segment, but the buttons are disabled.
5. Looking at the default PostgreSQL profile "Allow manual segment switch" is not checked.
I did try to find this information myself in the documentation but I only found this. Nothing specific to PostgreSQL.WinCC OA Assistant:Yes, you can perform a manual segment switch in NGA using a PostgreSQL database as the backend in WinCC OA.
6. I cannot modify the profile because it is currently used by a backend.Allows manual segment switch: Some databases (such as InfluxDB®) can only perform automatic segment switches.
7. I cannot (temporarily) change the profile of the backend. Once a profile is selected for a backend it cannot be changed anymore (the dropdown-menu is disabled). I could not find this behaviour in the documentation.
(Stopping the database or unchecking the Active checkbox did not change this behaviour)
My questions are:
1. Should changing the segment time for a segment automatically adjust the current segment?
2 If not: How can we change it, if manually switching is not possible (e.g. accidentially set it to 1 year instead of 1 hour)?
3. How can we modify the settings of a profile or change the profile of a backend without deleting the backend first?
4. Can a PostgreSQL backend manually switch the segments? WinCC OA Assistant says yes but it also says this
Thanks in advanceIn WinCC OA, NGA (Next Generation Archiving) does not support PostgreSQL as a backend for archiving.
Dennis
