Could not get DB version at Upgrade process
VictorCalvo
Post by VictorCalvo »
I am trying to upgrade a v3.10 Project to v3.18, but I get the following messages:
convertDb:-------------------------------------------------------------
convertDb:PVSS_II : C:\Siemens\Automation\WinCC_OA\3.18\config\config
convertDb:PVSS_II_PROJ : 3.18
convertDb:WCCOAtoolConvertDb(1), 2022.04.28 12:54:14.001: "3.10" does not match with manager version: "3.18" !!
convertDb:set PVSS_II=D:\WinCC_OA_Projects\3.10\Redundante_Server_04_01_2021\config\config
convertDb:WCCOAtoolConvertDb(1), 2022.04.28 12:54:14.037, SYS, WARNING, 54, Unexpected state, DoConvertDb, doConvert, D:\WinCC_OA_Projects\3.10\Redundante_Server_04_01_2021\ couldn't get database version
convertDb:WCCOAtoolConvertDb(1), 2022.04.28 12:54:14.040, DBG, -------------------------------------------------------
convertDb:WCCOAtoolConvertDb(1), 2022.04.28 12:54:14.040, DBG, DB conversion error. Aborted!
convertDb:DB conversion error (-1). Aborted at: 2022.04.28;12:54:14:040
I would like to know if, first of all, is it possible to make this upgrade (since 3.10 is pretty old).
If it is possible, I would like if it is necessary to make additional steps before the upgrade process. The project is already registered in v3.10 and the only thing I do is pressing the upgrade button at v3.18 Project Administrator.
If more information is needed, please let me know.
Thank you
Re: Could not get DB version at Upgrade process
An upgrade from 3.10 directly up to 3.18 should be possible.
Only with this small part of information we cannot detect what the problem is. Possibly the project is needed for further analysis.
If you need additional assistance please get in contact with your common WinCC OA support.
