I've noticed that sometimes when communication between server and client interrupts I got the following messages in PVSS_II logs on my Secondary DRS system (SSS).
WCCOActrl (1), 2021.12.20 12:24:43.431, CTRL, WARNING, 0, , User not found: <USER-NAME> login at <DRS_SSS-project name>:_Ui_<NUM>
WCCILdata (0), 2021.12.20 12:24:47.667, SYS, SEVERE, 229, The Manager <SCADA-CLIENT-MACHINE-NAME> is already running at host $2., MAN: (SYS: 0 Ui -num <NUM> CONN: 1(R))The messages happen only for the clients that are connected to the Secondary DRS project (background UIs).
We do not have such messages in normal operation or after client restart, only when communication breaks.
We are using Active Directory authentication login to WinCC OA, Single Sign-On option is deactivated for these workstations.
WinCC OA v.3.15.
No clue, why the background UI tries to attempt to sign in to SCADA by using the Windows user when communicating fails.
Some ideas will be highly appreciated.
