I have a problem with the InfluxDB manager.
Restarting WCCOAnextgenarch and the entire project did not fix this issue.
I'm using WinCC OA v3.17 P14.
Error log below:
WCCOAnextgenarch(118), 2021.11.10 09:24:07.314, IMPL, WARNING, 69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:07.531, IMPL, SEVERE, 69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:18.682, IMPL, WARNING, 69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:19.818, IMPL, SEVERE, 69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:29.930, IMPL, WARNING, 69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:31.221, IMPL, SEVERE, 69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:39.280, IMPL, WARNING, 69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:40.742, IMPL, SEVERE, 69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:50.756, IMPL, WARNING, 69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:52.293, IMPL, SEVERE, 69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:01.379, IMPL, WARNING, 69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:03.128, IMPL, SEVERE, 69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:11.486, IMPL, WARNING, 69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:13.121, IMPL, SEVERE, 69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:21.882, IMPL, WARNING, 69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:23.062, IMPL, SEVERE, 69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:31.755, IMPL, WARNING, 69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:32.606, IMPL, SEVERE, 69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:42.420, IMPL, WARNING, 69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:44.487, IMPL, SEVERE, 69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:53.366, IMPL, WARNING, 69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:54.462, IMPL, SEVERE, 69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
