Audit Trail
Audit Trail
Can I configure audit trail related functionality in demo license?Has anyone checked or impemented?If yes,Can any one briefly explain how to proceed?From manual I saw audit trail panel and related function
Re: Audit Trail
As far as I know the AuditTrail functionality can also be configured when using a demo license.
How to use the AuditTrail functions is described in the WinCC OA Documentation. if you want to save information for the AuditTrail you have to use the CTRL functions for it.
Re: Audit Trail
Can audit trail also be used with NGA InfluxDB?
Re: Audit Trail
AuditTrail should also work with NGA as it using archiving functionality.
The panel to configure AuditTrail does not show the NGA archive groups. If you change the archive configuration at the _AuditTrail datapoint it probably will work.
