(winccoa 3.12) Is it possible to access DP's ELE
Is there a way to access OPC values when I get and run the project in wincc oa 3.12 version?
Re: (winccoa 3.12) Is it possible to access DP's old/new comparsio
Normally you should be able to change the config by dpSet(<DPE>:_address.._lowlevel, FALSE).
Did you try making a GQ?
Thank you for your kind answer. It was a great help
