Dp create error
VictorCalvo
Dp create error
Post by VictorCalvo »
I am trying to create DPs but I've got an "unknown subroutine error" message, so the dp cannot be created. The error message is as follows:
PVSS00ui (8), 2021.06.03 11:16:12.395, CTRL, SEVERE, 5/ctrl, Location of the following log entry:
Module: Para_4
Panel: C:\Siemens\Automation\WinCC_OA\3.10\panels\para.pnl []
Object: 10 named: "activeX" of type: DP_TREE
Script: OnRButtonClk
Library: C:\Siemens\Automation\WinCC_OA\3.10\scripts\libs\mp.ctl
Line: 1300
PVSS00ui (8), 2021.06.03 11:16:12.395, IMPL, SEVERE, 33, General error in Data Manager, DataManager, handleManipDpMsg, unknown subroutine error
Commonly, the server where this happens has a runtime license, but when I need to do some specific tasks I change to development license. I've performed this procedure several times and this is the first time this occurs.
Also, when I try to create Dps with ASCII Manager, it returns error code -14.
I didn't see any license error, so I'm not sure if the license change is the problem. What can be the source of the problem?
Re: Dp create error
The problem is not related to the license you are using.
Possibly the database is damaged and therefore creating datapoints fails.
You can check if there other errors for the database are reported during start and/or runtime.
