a distributed system was setup. the system 13 and 14 are located within a test network which is connected with openvpn.
What is the problem with "Unexpected state, could not set msg version" ?
The system-overview-panel shows a yellow state for system 13 and 14. What does the yellow color mean?
(...copy/paste from log file...)
WCCILdist (1), 2013.01.14 08:44:59.507, SYS, INFO, 4, Connected to, (SYS: 13 Dist -num 1 CONN: 1) @ 172.24.17.13 (172.24.17.13)
WCCILdist (1), 2013.01.14 08:44:59.523, SYS, INFO, 4, Connected to, (SYS: 14 Dist -num 1 CONN: 1) @ 172.24.17.14 (172.24.17.14)
WCCILdist (1), 2013.01.14 08:45:01.913, IMPL, SEVERE, 54, Unexpected state, could not set msg version for the connection to "(SYS: 2 Dist -num 1 CONN: 1)". peer not found! at:3395 file:MsgItcDispatcher.cxx
WCCILdist (1), 2013.01.14 08:45:04.195, REDU, INFO, 3/dist, Closing connection to passiv peer MAN: (SYS: 13 Dist -num 1 CONN: 1)
WCCILdist (1), 2013.01.14 08:45:04.195, SYS, INFO, 181, Closing connection to (SYS: 13 Dist -num 1 CONN: 1)
WCCILdist (1), 2013.01.14 08:45:06.492, IMPL, SEVERE, 54, Unexpected state, could not set msg version for the connection to "(SYS: 2 Dist -num 1 CONN: 1)". peer not found! at:3395 file:MsgItcDispatcher.cxx
WCCILdist (1), 2013.01.14 08:45:08.773, REDU, INFO, 3/dist, Closing connection to passiv peer MAN: (SYS: 14 Dist -num 1 CONN: 1)
WCCILdist (1), 2013.01.14 08:45:08.773, SYS, INFO, 181, Closing connection to (SYS: 14 Dist -num 1 CONN: 1)
WCCILdist (1), 2013.01.14 08:45:08.773, SYS, WARNING, 39, Connection lost, MAN: (SYS: 13 Dist -num 1 CONN: 1), Connection reset by peer (10054)
WCCILdist (1), 2013.01.14 08:45:08.789, SYS, WARNING, 39, Connection lost, MAN: (SYS: 14 Dist -num 1 CONN: 1), Connection reset by peer (10054)
It might be a configuration problem, because the systems 23 and 24 are connected successfull. As well system 23 and 24 are located behind the openvpn link.
