Good day all ,
I have a question regarding tcp socket, in wincc the function tcpopen doesnt include a parameter to determine the socket type ,as you see below :
"int tcpOpen(string host, unsigned port [, time timeout]);"
Is there a way to use the wincc function as the below c# function which includes the socket type :
" IPAddress LoginIP = IPAddress.Parse("192.168.104.3");
Socket Socket = new Socket(AddressFamily.InterNetwork, SocketType.Raw, ProtocolType.Tcp);
Socket.Connect(LoginIP, 8020); "
Regards and thank you
TCP connection type raw
Re: TCP connection type raw
There is no such option. tcpOpen() always opens a stream socket
But the message server that we are dealing with only accepts tcp socket type raw .
Please do you suggest any method to open channel from wincc , as what we get when using the top open is the access is accepted but no more , meaning no data transactions.
Regards and sorry for the inconvenience
You can maybe implement a C++ extension (loaded in a CTRL manager) or a WinCC OA API manager to open a TCP connection with the options needed.
Good day ,
Is there any other suggestion?
Has anyone here implemented such kind of solution to share with me .
Thank you all
Thank you all
Besides using the API (or ordering a feature request) there are no other solutions possible.
Since you seem to have C# experience, you could create a C# WinCC OA API manager. If C++ is not a problem you could create a control extension.
