Wrong available space on HDD
7 posts • Page 1 of 1
funkey
Post by funkey »
Is there a patch to show the right available space on HDD?
Information from Para
_ArchiveDisk
TotalKB: -2147483648
UsedKB: 827192688
AvailKB: 1320290452
FreeKB: 1320290452
AvailPerc: -60
FreePerc: -60
Status: OK
Re: Wrong available space on HDD
without detailled knowledge about your installation (WinCC OA-version, operating system, size of the HD) we cannot tell you if there is a solution available.
Please refer to the official support address support.automation@siemens.com.
When sending the information to the official address please include the information which WinCC OA-version and which operating system you are using.
funkey
Post by funkey »
Thank you for answering.
We use PVSS 3.9 running on
SUSE Linux Enterprise Server 11 SP1
Kernel 2.6.32.12-0.7-default
/home 2,8TB size 1,5TB used
mweber
Post by mweber »
Hi Christoph,
it looks like your hard drive is too big ;-)
all the values (total, free,...) are stored on internal datapoints (in kB) where the data type is defined as integer.
2,8 TB is a liitle bit too much for int range - (therefore the overflow to negative values) sorry for that.
It is the same in the releases 3.10 and 3.11 - we will consider that issue for future releases.
have a nice day
Markus
P.S.: as a temporary workaround you could change the data type _DiskSpaceCheck with the PARA tool and modify the TotalKB element to be unsigned integer - that should help (at least till your harddrives are below 4TB)
funkey
Post by funkey »
Thank you Markus,
I changed the element to be an unsigned integer, but there is still a negative value (-2147483648 !!??) in the UNSIGNED Integer in TotalKB. And I get following error message:
PVSS00data   (0), 2012.08.14 07:34:01.887, PARAM,SEVERE,     54, Unexpected state, ValHistEngine, setValue, Falscher Variable-Typ
System1:_ArchivDisk.TotalKB:_original.._value (Type: 10 Sys: 1 Dp: 122 El: 12 : _original.._value)
INTEGER_VAR
it looks like the work around cannot be used due to the fact, that the data-manager is expecting an integer value.
Maybe it works when the project is restarted.
Otherwise please take back the changes and restart the project to avoid this log-message.
We have already informed our development department about this problem when using very large discs.
When a solution will be available we cannot tell you right now because we are still investigating the cause for the problem.
funkey
Post by funkey »
I restartet the server without success. Now I changed the datatype back to (signed) integer. :(
I hope that there will be a solution some day.
