Differentiate Between Gedi(Edit) instance and vision(Running) instance of EWO.
Kshitij Mayekar
Post by Kshitij Mayekar »
How can I differentiate between Between Gedi(Edit) instance and vision(Running) instance of EWO in the EWO source code ?
Here is what I have tried.
//ewo.h file
Q_PROPERTY(bool inGedi READ isInGedi WRITE setInGedi DESIGNABLE false SCRIPTABLE false)
public:
bool isInGedi() const
private:
bool inGedi
//ewo.cpp
MyWidget::MyWidget(QWidget *parent)
  : QWidget(parent)
  qDebug ()
Re: Differentiate Between Gedi(Edit) instance and vision(Running) instance of EWO.
Pleae have a look at the following thread:
https://portal.etm.at/index.php?option= ... 16&id=4780
At this thread the same/a similar topic is discussed.
Basics in C++: initialize your members!
And inGedi will never tell you anything just inside the constructor, since it can only be set after construction of the object.
