Another error in AES.ctl
mustafa.toker@siemens.com
Post by mustafa.toker@siemens.com »
Hello again,
We have troubles with that AES.ctl. Although we thought that we did not do sth illegal we are receiving following errors. :blink: :dry:
Really annoying :S
Can anyone help?
Mustafa
PVSS00ui (7), 2011.11.24 18:22:08.218, CTRL, WARNING, 5/ctrl, Location of the following log entry:
Module: PVSS-AES
Panel: C:\\ETM\\PVSS2\\3.9\\panels\\vision\\aes\\AEScreen.pnl []
Object: 1 named: "table_top" of type: TABLE
Script: Initialize
Library: C:\\ETM\\PVSS2\\3.9\\scripts\\libs\\aes.ctl
Line: 5372
PVSS00ui (7), 2011.11.24 18:22:08.218, SYS, WARNING, 6/aes, Creating config matrix / Undefined function!, dpGetDescription
Module: PVSS-AES
Script: Initialize
Line: 5372
PVSS00ui (7), 2011.11.24 18:22:08.218, SYS, WARNING, 6/aes, Creating config matrix / Undefined function!, direction
Module: PVSS-AES
Script: Initialize
Line: 5372
PVSS00ui (7), 2011.11.24 18:22:08.218, SYS, WARNING, 6/aes, Creating config matrix / Undefined function!, dpFormatValue
Module: PVSS-AES
Script: Initialize
Line: 5372
PVSS00ui (7), 2011.11.24 18:22:08.218, SYS, WARNING, 6/aes, Creating config matrix / Undefined function!, ackState
Module: PVSS-AES
Script: Initialize
Line: 5372
PVSS00ui (7), 2011.11.24 18:22:08.218, SYS, WARNING, 6/aes, Creating config matrix / Undefined function!, nofComments
PVSS00ui (7), 2011.11.24 18:22:08.280, CTRL, WARNING, 5/ctrl, Location of the following log entry:
Module: PVSS-AES
Script: Initialize
Line: 5372
PVSS00ui (7), 2011.11.24 18:22:08.264, SYS, WARNING, 6/aes, Creating config matrix / Undefined function!, getExtTimeId
PVSS00ui (7), 2011.11.24 18:22:08.296, CTRL, WARNING, 5/ctrl, Location of the following log entry:
Module: PVSS-AES
Script: Initialize
Line: 5372
PVSS00ui (7), 2011.11.24 18:22:08.296, SYS, WARNING, 6/aes, Creating config matrix / Undefined function!, getACount
Re: Another error in AES.ctl
only from these log-messages we cannot identify the problem.
It looks like some configuration within your project is not correct, the messages describe that some standard-functions cannot be found.
Please send an e-mail to the official support address support.automation@siemens.com.
You'll then receive an answer with details how the cause can be found or which information is needed for the analysis.
