RDB SetUp - ORA-29540 Error
jujinp
Post by jujinp »
Hi.
We plan to use RDB Oracle Archive/compress.
First, I checked config file ,then executed win_install.bat.
I set use_java = "yes"
But there is some error ,see the attached file(korean lang).
Other Windows Machine is same problem(RDB SetUp) also.
-- Connection to C-DLL or Java Source: 1 -> ok
select 'setup - connection to extern source: '||
(case when arc_xpi.TestArc(1)=1
then 'OK'
else 'FAILED! 1/'||arc_xpi.TestArc(1)
end) from dual;
Above query is problem.
Second, above installation operates normal RDB archive.
But RDB Archive Compression is NOT. there is no sub tree element,see attached img.
PVSS Help file show the some element ,and add some interval. But I have not any thing,add interval button is inactive state.
winXP Oracle 10.2.0.1 -> 10.2.0.5 (Patched)
Windows XP PVSS 3.9
Please I need some help.
Thank you in advanced. Image
Re: RDB SetUp - ORA-29540 Error
Dear Jujin Park,
please notice that the ETM portal does not subsitute the regular PVSS Support.
Therefore please get in contact with the PVSS Support using one of the possibilities described in the following FAQ
http://portal.etm.at/index.php?view=ite ... &Itemid=54
