Hello!
This posting only applies to distributed projects running WinCC OA 3.19 P015 and using the "Dist Sync Feature".
You can simply detect if your project is affected by checking if the project runs the script distSyncMan.ctl.
During internal tests we found an issue in the script distSyncMan.ctl which can cause a high system load.
The problem is already fixed and will be included in the upcoming patch 3.19 P016.
It is strictly recommended to use the modified script until patch P016 is officially available to prevent problems in your distributed system.
If the modified script is needed please submit a service request via the Siemens Industry Support referring to this forum posting.
Important Info - distSyncMan.ctl Hotfix (only 3.19-P015 affected)!
