Datamanager Not started
hakan
Post by hakan »
The project was not stopped normally, the computer closed. When the project started again, the error occured and "Datamanager" not started. The occured error is below. How can I do to start project?
WCCILdata (0), 2022.11.08 16:22:52.190, SYS, INFO, 0, , Initializing last value cache
WCCILdata (0), 2022.11.08 16:22:52.909, SYS, SEVERE, 69, Database error, StVLastVariableUtils, loadVariable, Db : lastval\ValHist -1- Addr : 319018951 VarType : 3014656 Code : 6
WCCILdata (0), 2022.11.08 16:22:52.909, IMPL, SEVERE, 54, Unexpected state, LastValueCache, init, Datenbank-Letztwert repariert (Originalwert)
_Mod_Plc_103.UserFC64.Response:_original.._value (Type: 0 Sys: 0 Dp: 10431 El: 22 : _original.._value)
funkey
Re: Datamanager Not started
Post by funkey »
Hello!
Are these all error messages you get when starting the project?
I once had a similar problem, but there was a message that mentioned some kind of lock file. I had to delete/rename the lock file and the project started again.
But your problem seams to be something different...
What WinCC OA do you use?
hakan
Post by hakan »
The project ver is 3.15
The small part of the log messages do not show any information that the project does not start.
If you need further assistance for this issue please get in contact with your common WinCC OA support.
You have to take into account that WinCC OA 3.15 is no longer officially supported since May 2021.
