DP to TrendRulerPanel.pnl
Kirvesmies
Post by Kirvesmies »
I'm sure this has been asked before, but I cannot find solution via search.
How can I get the DP-name also to the trendruler. As default is shows only DP's description, value and unit. I tried to look at the code in TrendRulerPanel.pnl but if I modify that, I'm afraid it will not work after upgrading WinCC versions without maintaining this code.
Re: DP to TrendRulerPanel.pnl
I would expect the TrendRulerPanel to use the name of the curves, so setting the DP name to the curve should do the trick.
The TrendRulerPanel uses the curve names to get the information which curves are displayed. It does not read the information for the DP elements assigned to a curve. You can also fill a trend without assigning a DP element.
Kirvesmies
Yes thanks.
I added the third row to my code for adding curves to trend. Without it it defaults to naming the curve according to description only.
  TREND1.addCurve( 0, "#1_1" );
  TREND1.connectDirectly( "#1_1", sDP );
  TREND1.curveLegendName( "#1_1", dpSubStr(sDP, DPSUB_DP) +", "+dpGetDescription(sDP));
