IP Camera RTSP Streaming
jonred
Post by jonred »
I’m trying to stream an IP camera over RTSP using VLC ActiveX but I’m no table to achieve it. However, If I stream over HTTP, using the same configuration, it works. I have changed the MRL extended parameter only in both cases.
If I try to connect over RTSP using VLC out of WinCC OA, it works. I don’t know if some extra steps are needed to configure the connection through RTSP with the VLC ActiveX in WinCC OA. There are no log files reporting the error.
It is possible to connecto through RSTP using this method?
Thank you,
adaneau
Re: IP Camera RTSP Streaming
Post by adaneau »
Hey,
I did that 10 years ago with 3,11 :D . It worked fine with siemens camera in RTSP. Here is how I did it:
int item=VideoLAN_VLCPlugin.playlist.add("rtsp://1.2.3.4:555");
VideoLAN_VLCPlugin.playlist.playItem(item);
Don't forget to clear playlist if you are gonna use another stream:
VideoLAN_VLCPlugin.playlist.stop();
VideoLAN_VLCPlugin.playlist.clear();
I hope it will help you.
Alex
If you want to show video streams in WinCC OA you can use the WinCC OA Video AddOn.
For details please have a look at the documentation:
https://www.winccoa.com/documentation/W ... video.html
