Unsupported data type 589824
sblancha
Post by sblancha »
I have the warning "Unsupported data type 589824" in the log. but how to know what is this data type XXXXXX ?
Sebastien
Re: Unsupported data type 589824
Can you please copy the complete log message.
Without seeing the content of the log message we cannot identify which manager has written the log entry.
sblancha
Post by sblancha »
It comes from a UI and it is related to a dpConnect required to animate my EWO:
WCCOAui (1), 2019.10.15 08:34:12.836, CTRL, WARNING, 51, Parameter incorrect,
Module: Vision_1
Panel: C:\PVSS_projects\lhc_test\lhc_test\panels\vision\mainViews\MainLHC.pnl [LHC Vacuum]
Object: 0 named: "Layout" of type: MainViewLhc_ewo
Script: dpConnectRequest
, LhcVacNewOnlineValue, Unsupported data type 589824
Can you please add the code snipped for the function where the problem occurred.
Maybe we can then see what the cause for the error is.
sblancha wrote: Tue Oct 15, 2019 9:11 am I have the warning "Unsupported data type 589824" in the log. but how to know what is this data type XXXXXX ?
Convert the value to hex (0x00090000), search for this value in '<API_ROOT>/Libs/Basics/Variables/Variable.hxx' and find 'BIT32_VAR'.
sblancha
Post by sblancha »
Thanks, it gives me a hint.
Sebastien
