Mobile UI
Eksergian
Mobile UI
Post by Eksergian »
I'm trying to run my WinCC OA 3.16 project in my smartphone and in a tablet (with the proper apps), both Android higher than 4.4.
To do so, I've created a control manager with "webclient_htttp.ctl" running, and also created a config.webclient. In both config and config.webclient I've added data and event (let's say my IP is 123.345.67.8) as
data = "123.345.67.8:4897"
event = "123.345.67.8:4998"
With Desktop UI it works. I even changed the "rootPanel" to another one. But with the smartphone and/or Tablet it wont work. In the smartphone it logs the error:
Error in communication with HTTP server:
http://123.345.67.8:80/_info?sessionToken=x
Connection refused
http://123.345.67.8:80/_info?projectName=x
Connection refused
Initialization via HTTP server failed
Note: Both in the smartphone and table I enter my IP and uncheck the "Secured connection" checkbox. I've tried also to fill the other fields too.
I'm not used to manage servers/networks so I don't have a clue of what's happening. It could be related (or not) to each device using a different internet source. Or maybe I should have done something else.
Any help would be appreciated.
Re: Mobile UI
You can activate the debug flag "-dbg http" for the CTRL manager running the script webclient_http.ctl.
Maybe the output generated by this debug flag helps to find the cause for the problem.
