Hi everyone
How can I start and stop a Manager via CTRL-script? Is there such a function?
I tried it with a tcpWrite command (MGRLIST) but I recive "ERROR no Auth : unknown authorisation".
I wrote the command with the root-user.
Aleks
Starting and stopping Manager via CTRL-Script
aleksandar.postolov
Re: Starting and stopping Manager via CTRL-Script
Please have a look at the following thread
viewtopic.php?f=16&t=10343&p=964789&hil ... er#p964785
aleksandar.postolov
Thank you very much - just saw this a couble of hours ago.
But this isn't working neither. I try to start and stop a OPC-Driver
_Managers(_2).Exit doesn't work. I write the Manager PID and nothing happens.
Logviewer: WCCILevent (0), 2019.05.28 11:08:57.659, PARAM,INFO, 0, , Terminate manager (SYS: 0 None -num 2 CONN: 2)
If I use the commands from the pmon.ctl - there is a warning in the logviewer - variable not defined: gTcpFileDescriptor2
I overwrote the pmon.ctl and defined the variable. But the next warning is:
Line: 185: tcpWrite: Socket Nummer (0) illegal oder Socket nicht geöffnet.
Best way to do is
system( "WCCILpmon.exe -command SINGLE_MGR:START 13" );
this works
Best way to do is
this works
Possibly the manager ID you have written to _Managers(_2).Exit was not correct and therefore it did not work.
The manager ID you get by using the CTRL function convManIdToInt().
Please take into account that the functions defined in pmon.ctl are designed for internal use, therefore no documentation is available.
Also when using these functions some prerequisites (.e.g global variables) must by fulfilled, otherwise the functions will not work.
