Script to filter alerts
11 posts • Page 2 of 2
Mgiacome
Re: Script to filter alerts
Post by Mgiacome »
So, I've managed to accomplish a sort of dynamic filter on AES panels. The filters are the DP list, a PRIORITY and a STATE
The following function creates a new AEScreen internal DP with the current UI number as index (so each user has a different and customized AEScreen); it also creates a new AESProperty internal DP, and makes the relative association between AEScreen and AESProperty; it sets the filters and removes the cache.
I don't know if there are different ways to accomplish this goal, but the approach seems quite neat to me.
void openCustomAES(dyn_string dps, int FILTER_PRIO = 0, int FILTER_STATE = 0) {
    1. Search in the AESScreens' DPs if there is a DP with name = _AEScreen_UI_ + nrUI
    2. If it doesn't exist, create it (copy from another AEScreen DP)
    3. Search in AESProperties if there is a DP with name = AESProperty + nrUI (starting from 9000)
    4. If it doesn't exist, create it (copy from another AESProperty DP)
    5. Set in the AEScreen DP the corresponding property name+nrUI
    6. Modify the filters of the property name+nrUI
    7. Launch AEScreen with the previous configuration
  // 1.
  int NrUi = myUiNumber();
  dyn_string _other_dps = dpNames("*","_AEScreen");
  string AESDP = "_AEScreen_UI_" + NrUi;
  bool aesdp_exist = false;
  for(int y= 1; y <= _other_dps.count(); y++) {
    if(_other_dps[y] == AESDP) {
      aesdp_exist = true;
      break;
  //2.
  int err;
  if(!aesdp_exist) {
    if( !dpExists( AESDP ) )
      dpCopy( "_AEScreen_0000", AESDP, err );            //copy dp structure
      dpCopyOriginal( "_AEScreen_0000", AESDP, err );    //copy dp config
      if( err != 0 )
         DebugN("Errore nella copia", err);
    DebugN("DP copied", AESDP);
  string aes_name = "aes_ui_" + NrUi;
  dpSetWait(AESDP + ".Name" + AES_ORIVAL, aes_name);
  dpSetWait(AESDP + ".Bot.Active" + AES_ORIVAL, FALSE);
  //3.
  dyn_string _other_property_dps = dpNames("*","_AESProperties");
  string AESDP_PROPERTY = "_AESProperties_" + (9000+NrUi);
  bool aesdp_property_exist = false;
  for(int x= 1; x <= _other_property_dps.count(); x++) {
    if(_other_property_dps[x] == AESDP_PROPERTY) {
      aesdp_property_exist = true;
      break;
  //4.
  int err_property;
  if(!aesdp_property_exist) {
    if( !dpExists( AESDP_PROPERTY ) )
      dpCopy( "_AESProperties_0002", AESDP_PROPERTY, err_property );            //copy dp property structure
      dpCopyOriginal( "_AESProperties_0002", AESDP_PROPERTY, err_property );    //copy dp property config
      if( err_property != 0 )
         DebugN("Copy error", err_property);
    DebugN("DP PROPERTY copied", AESDP_PROPERTY);
  //update property name with NrUi index
  string p_name = "aes_dyndp_ui_" + NrUi;
  dpSetWait(AESDP_PROPERTY + ".Name" + AES_ORIVAL, p_name);
  //5.
  dpSetWait(AESDP + ".Top.Config" + AES_ORIVAL, p_name);
  //6.
  //set DP list
  dyn_string _dps2 = dps;
  _dps2.append("_Config");
  dpSetWait(AESDP_PROPERTY + ".Alerts.Filter.DpList" + AES_ORIVAL, _dps2 );
  //set filter priority
  // 0 = no priority filter
  dpSetWait(AESDP_PROPERTY + ".Alerts.Filter.Prio" + AES_ORIVAL, FILTER_PRIO );
  ShowOnly pending = FALSE
  0 = All
  1 = Unacknowledge
  5 = Acknowledge
  7 = Non-acknowledgeable
  8 = Oldest acknowledgeable
  ShowOnly pending = TRUE
  2 = All
  3 = Unacknowledge
  4 = Acknowledge
  6 = Non-acknowledgeable
  dpSetWait(AESDP_PROPERTY + ".Alerts.FilterState.State" + AES_ORIVAL, FILTER_STATE );
  //remove cache
  dpRemoveCache(AESDP);
  dpRemoveCache(AESDP_PROPERTY);
  // 7.
  //open AES Screen with previous config
  openAES(aes_name, TRUE, AES_ACTION_AUTORUN );
