I have a little suggestion about the 'Delete multiple datapoints' option of the PARA.
Often i use the DP filter to find the datapoints i must delete, but then i have to delete them individually. Could be possible that the multiple datapoints option also uses the DP filter? This would be really usefull.
Thanks.
Delete multiple datapoints by DP filter
Re: Delete multiple datapoints by DP filter
Hey you can use dpNames and dbDelete
hey, yes i know. It's just that i like to use the UI sometimes, to do not being scripting everything
- hpuchegger
This is currently not possible via the Para/UI. If you would like this functionality as a feature request, you can submit a support request and we will check whether this is feasible and what effort this would involve.
Br, Herbert
Br, Herbert
That was just a little suggestion, ican do my own panel as kilian said.
