I am testing about mobile ui
my mobile ui web server version is wincc oa 3.14
and mobile app version is 3.18 patch 2 ( downloaded app from app market on my mobile phone - galaxy note 10 plus )
I showed the youtube this url ( https://www.youtube.com/watch?v=ysWTvGRoJqI )
I made all same. It was worked on chrome browser. but I got a error on mobile ui below.
Connection not possible, WCCILdata.
WCCOAui (201),2021.06.08.13:18:35.394, PARAM,WARNING, 224 Security issue:Username or Password entry found in config file!
WCCOAui (201),2021.06.08.13:18:35.646, SYS,INFO, 1,Manager Start, PROJ, CLI_IWT, V 3.18 - not initialized
WCCOAui (201),2021.06.08.13:18:35.904, SYS,INFO, 3,Trying to connect to (SYS:0 Data -num 0 CONN:1)@192.168.11.220:9777
WCCOAui (201),2021.06.08.13:18:35.919, SYS,INFO, 4,Connected to (SYS:0 Data -num 0 CONN:1)@192.168.11.220(192.168.11.220)
WCCOAui (201),2021.06.08.13:18:36.921, SYS,INFO, 0,Connection from 192.168.11.220 expired
WCCOAui (201),2021.06.08.13:18:36.938, IMPL,FATAL, 5,Connection not possible, WCCILdata
Do you have any idea to solve problem. ?
mobile ui
Re: mobile ui
You can have a look at the log files at the server, maybe there are log messages written which help to find the cause.
Also you can try to start a Desktop-UI on a PC to check if a remote UI works.
When you are using a browser to show the UI the UI manager is started at the server and only graphical information is shown on the client (ULC UX client).
Re: mobile ui
Remote UI ( ULX UX ) is working on the pc chrome browser.
only mobile version is not working.
Below is log on the web server when I tried to connect ( This log was showing in 2 or 3 second after error message was showing on the mobile phone.
WCCILdata (0), 2021.09.15 16:14:06.782, SYS, INFO, 4, Connected to (SYS: 191 Ui -num 202 CONN: 1) @ ::ffff:192.168.11.46 (::ffff:192.168.11.46)
WCCILdata (0), 2021.09.15 16:14:06.785, SYS, WARNING, 39, Connection lost, MAN: (SYS: 191 Ui -num 202 CONN: 1), Connection reset by peer (10054)
Re: mobile ui
I connected with server but I met another problem.
I added MultiPlexing Proxy on the project console and comment out #mxProxy = "none" on the config file.
Then mobile ui was connected.
It is showing login page on the mobile . but I want to show my screen instead of login page.
when I show it on PC. the url is http://192.168.11.40:6100/data/ulc/start.html then it is showing my page.
Below is mobile version log, I push the server on the mobile few second, then send the log to server.
WCCOAui (205), 2021.09.15 17:48:20.383, WinCC_OA, (1), 2021.09.15 17:41:30.619, Qt, QMetaObject::invokeMethod: No such method QListWidget::inputMethodQuery(Qt::InputMethodQuery,QVariant)
(1), 2021.09.15 17:46:33.850, Qt, QMetaObject::invokeMethod: No such method QListWidget::inputMethodQuery(Qt::InputMethodQuery,QVariant)
Error in communication with HTTP server: requested
http://192.168.11.40:6100/_info?sessionToken=x
HTTP code=404 Not Found
WCCOAui (0), 2021.09.15 17:48:20.215: PARAM/WARNING: using PVSS_II_ROOT /data/user/0/com.siemens.winccoaui/cache//pvssInst.conf
"WCCOAui [/data/user/0/com.siemens.winccoaui/cache/CLI_IWT_WEB_09082021/config/config]": pvss_path nonexistent, inaccessible or not a directory: C:/Siemens/Automation/WinCC_OA/3.14/
WCCOAui (205), 2021.09.15 17:48:20.216: WARNING: pvss_path "C:/Siemens/Automation/WinCC_OA/3.14/" in config file does not match with registered installation: "/data/user/0/com.siemens.winccoaui/cache/" !
WCCOAui (205), 2021.09.15 17:48:20.216: "3.14" does not match with manager version: "3.18" !!
WCCOAui (205), 2021.09.15 17:48:20.307: cannot set locale "en_US.iso88591"
Re: mobile ui
The settings for MxProxy must fit on the server and client.
You can check if your are using a config and a config,webclient file and which settings you have made.
If you need further assistance you can possibly get in contact with your common WinCC OA support.
