I am using WinCC OA 3.17 P004 on Windows server 2019 standard OS. As explained from your side, archiving design as displayed in Figure 1 is not supported yet, so I am testing the next viable option, as indicated in Figure 2.
Figure 1:
Figure 2:
The issue that I am observing with Figure 2 design is that DB schema of winccoa database in external influx databases is not updated (even if I add a new archiving group) while DB schema of winccoa database in local influx database is updated correctly.
Is it possible that I missed some step in configuration of Remote backends or is it required to update external influx DB schema manually each time an archive group is added or when retention policy is changed in WinCC OA Sys Mngmnt -> Database Configuration?
Do you know if the remote database works correctly if only the backend for the remote database is used/activated?
You have written that you have installed 3.17 P004.
Please do an upgrade to the newest patch for 3.17 as with P010 a lot of changes/improvements have been made in the NGA manager.
I can connect to the remote database remotely using influx CLI and telegraf and observe database structure (since no WinCC OA data is pushed into the database). I also manually created winccoa database.
Do you consider this as a valid indicator for "working correctly"?
Long story short: Should I expect WinCC OA P01X to automatically create the winccoa influx database and the series corresponding to archive groups or is db schema something that one has to do manually for remote database?
InfluxDB Is a "schemaless DB", there is no fixed schema as in relational DBs.
So also the structure of the "table" itself can handle adding of new "columns" at runtime without special DB manipulations and new archive groups are created "on demand" (i.e. also no "schema upgrade" is required).
It is highly recommended to install the newest patch for WinCC OA 3.17 as it includes a lot of improvements for the NGA manager.
The upcoming patch P012 for WinCC OA 3.17 will also include an update of the NGA manager.
