at a running WinCC project we want to switch to the OS auth user administration. For security reasons, the server-side auth (at first for UI only) should be used. Then, according to online help, it is no longer possible to use the user root: But how do you log into the gedi? What's the workflow without a user root?
If you havent changed anything in default users, "para" without password should make it. It basically have the same permissions as root in a default WinCC OA project. Then you should just create your own root user to be used.
but how do you log in with another username? I start an User Interface with paramenter "-m gedi" and the root password is asked. I cannot find a parameter like "-user para".
