Is there a way to create a list, array or dyn_... of ctrl++ objects? Or can I implement a generic list?
With kind regards
Philipp
ctrl++ object list
philipp.wechsler
Re: ctrl++ object list
There is an easy way to create a list of objects with dyn_anytype. After troubleshooting I found the bug of my problem.
The order of the classes in the same script is critical!
Dosn't working MWE:
If I change the order of classes then can I use classes as parameter and return value in functions. Another solution exists with separate scripts for each class.
MWE:
Is there a possibility of forward declaration in ctrl ++?
Dosn't working MWE:
class MyObject1
private string sName;
private dyn_anytype daObjects;
public MyObject1( string sName = "" )
this.sName = sName;
public void append( MyObject2 pObject )
dynAppend( daObjects, pObject );
public MyObject2 getObject( int pNumb )
return daObjects[pNumb];
class MyObject2
public MyObject( string sName = "" )
this.sName = sName;
};MWE:
class MyObject2
this.sName = sName;
class MyObject1
this.sName = sName;
