How to visualize Hex Value of a BIT32
laurent.brugeaud
Post by laurent.brugeaud »
Hi.
How to simply put on label the Hex value of a Bit32 DPE?
RudiKreiner
Re: How to visualize Hex Value of a BIT32
Post by RudiKreiner »
Not exactly sure what you really mean, but if you want to display a bit32 value as a hex number, you can do it with this code, where DP_NAME is a string containing the name of your datapoint.
dpSetFormat(DP_NAME, "0X%04x");
bit32 value;
dpGet(DP_NAME, value);
DebugN(dpValToString(DP_NAME, value));
Be aware that the format displayed in the common config the datapoint in para will look strange though, and don't try to change it there.
laurent.brugeaud
Thanks you Rudi. It work well.
