DRS Client behavior - some additional hints
1 post • Page 1 of 1
eivanovic
Post by eivanovic »
Some additional hints for client behavior at DRS, which are not mentioned in the help:
- On one client 2 Remote UI projects must be established, one connected to the PSS, the other to the SSS.
- Both projects must have the same managers with the same manager numbers
- The Visu-Control Button (which itself can be invisible) must be located on a part of the panel, which is always visible, e.g. the info module.
- Both UIs must run; the Visu-Control Button handles which UI should be in the foreground
- With the not described $-Parameter “$sStartOptions” you can define additional options for the UI to be started, when clicking on the Visu-Control Bitton (e.g.: -titleBar -iconBar)
