I have the following issue with the axes of the ewo bar chart. When the width of a section is smaller than the "text," the axis labels are displayed with "..." (see image "example").
Is it possible to solve this issue using, for example, stylesheets or other methods without adjusting the font size? If anyone has additional suggestions, I’d appreciate it.
Thank you very much!
Alex
Ewo bar chart axes not displayable
Re: Ewo bar chart axes not displayable
Your posting does not contain a screenshot.
If you need assistance we suggest to use the official Siemens Industry Support instead of the WinCC OA Forum.
https://www.winccoa.com/support.html
When you want to get input from the community we suggest to copy the panel instead of a screenshot. Then members of the community can exactly use your example and may try to find a solution.
