What is the recommended approach to upgrade a PVSS v3.1 project to WinCC OA v3.18?
Is it possible to directly upgrade to v3.18? Or should we do the upgrade in several steps?
Like for instance upgrade from v3.1 to v3.7 to v3.14 to v3.18?
To test the upgrade process I have tried to upgrade the project from 3.1 to 3.7 but unfortunately the upgrade process takes too long (since I don't have a v3.7 license).
Furthermore I have tried to upgrade the project from v3.1 to v3.14, but this stops at the conversion of the lastval DB.
So, should it be possible to upgrade a v3.1 project using the build-in upgrade functionality? Or should we upgrade the project manually? And if so whats steps do we need to take in that case?
Upgrade PVSS v3.1 to WinCC OA v3.18
Re: Upgrade PVSS v3.1 to WinCC OA v3.18
Probably a direct upgrade from 3.1 to 3.18 will work if a valid license is installed.
If a upgrade from 3.1 to 3.18 is possible from a technical point of view depends on the configuration of the project running version 3.1, e.g. the used type of archiving, the used languages, ....
ETM offers also the possibility for a project review by the Consulting Team. During the project review possible issues during the upgrade can be identified.
If you need more detailed information please get in contact with your common WinCC OA support or your WinCC OA sales contact.
- Programmer
Thank you for your reply.
Could you please tell how to contact WinCC OA support? By using the Siemens portal?
We have previously asked our Siemens (WinCC OA) sales contact, but unfortunately we didn't get the desired information.
Information for the WinCC OA Support you can find at the following page:
https://www.winccoa.com/support.html
Please take into account that you need a valid support contract if you want to get in contact with the WinCC OA support team.
For details concerning your contract please get in contact with the WinCC OA sales team.
