Datamanager Not started
Posted: Wed Nov 09, 2022 10:36 am
by hakan
The project was not stopped normally, the computer closed. When the project started again, the error occured and "Datamanager" not started. The occured error is below. How can I do to start project?
WCCILdata (0), 2022.11.08 16:22:52.190, SYS, INFO, 0, , Initializing last value cache
WCCILdata (0), 2022.11.08 16:22:52.909, SYS, SEVERE, 69, Database error, StVLastVariableUtils, loadVariable, Db : lastval\ValHist -1- Addr : 319018951 VarType : 3014656 Code : 6
WCCILdata (0), 2022.11.08 16:22:52.909, IMPL, SEVERE, 54, Unexpected state, LastValueCache, init, Datenbank-Letztwert repariert (Originalwert)
_Mod_Plc_103.UserFC64.Response:_original.._value (Type: 0 Sys: 0 Dp: 10431 El: 22 : _original.._value)
Re: Datamanager Not started
Posted: Thu Nov 10, 2022 7:35 am
by funkey
Hello!
Are these all error messages you get when starting the project?
I once had a similar problem, but there was a message that mentioned some kind of lock file. I had to delete/rename the lock file and the project started again.
But your problem seams to be something different...
Posted: Thu Nov 10, 2022 9:31 am
What WinCC OA do you use?
Posted: Sat Nov 12, 2022 1:58 pm
by hakan
The project ver is 3.15
Posted: Mon Dec 12, 2022 9:37 am
The small part of the log messages do not show any information that the project does not start.
If you need further assistance for this issue please get in contact with your common WinCC OA support.
You have to take into account that WinCC OA 3.15 is no longer officially supported since May 2021.
