Please see the title :dry:
It troubled me very much.
Does Wincc OA support QtQuick controls?
Re: Does Wincc OA support QtQuick controls?
We don't support it directly. What you can do is to implement an ewo which creates a QQuickWidget, which can then load a qml file.
However we do not deliver all the qml components/libraries from Qt which will be needed when you want to use QtQuick controls, so
you would have to deliver them on your own.
- jiaofueric
Thanks a lot , Sir
I tried it according your method But it still doesn't work
Attach my code...
thank you for your help
Eric
Attach my code...
//.h
#include
#include
class MyWidget : public QWidget
Q_OBJECT
public:
MyWidget(QWidget *parent);
signals:
protected:
private:
QQuickWidget *myQmlWidget;
//.cpp
EWO_PLUGIN( myQml )
MyWidget::MyWidget(QWidget *parent)
: QWidget(parent)
this->myQmlWidget = new QQuickWidget();
QUrl url("qrc:/firstQml.qml");
// myQmlWidget->setResizeMode(QQuickWidget::SizeRootObjectToView);
myQmlWidget->setSource(url);
QVBoxLayout *myLayout = new QVBoxLayout(this);
myLayout->addWidget(myQmlWidget);
this->setLayout(myLayout);
Eric
I once implemented such an ewo as a prototype. Find it attached here.
This code can also use datapoint values to act on properties. https://www.winccoa.com/fileadmin/image ... /Quick.zip
- Attachments
- Quick.zip
- (5.69 KiB) Downloaded 303 times
- jiaofueric
Thank you very much ,Sir
But I can't download it now
The server return information as below:
Not Found
The requested URL /images/fbfiles/files/Quick.zip was not found on this server.
Please see the attached....
Could you send it wo my email?
my email is : jch@lailibai.com
Eric
Not Found
Eric
I have uploaded it again.
- jiaofueric
It Works
Thank you Sir
Thank you Sir
- jiaofueric
Copy that
Thanks a lot
:cheer: :cheer: :cheer: :cheer: :cheer:
Thanks a lot
