hi
any body has an idea how to built an automated testing tool to test if a pvss project works correctly ?
some kind of black box test.
test tool for Pvss project
Re: test tool for Pvss project
some tests you can do with standard functionalities.
Which tools can be used depends on the tests you want to make.
WinCC OA contains a lot of functionality (alarming, redundancy, archiving, driver communication, ....) and there is no tool available to test all functionalities at once.
We use often CTRL-scripts for the simulation of PLC values, for reporting tests you could use the Excel Report for example.
- achka
Re: test script for panels error
hi, thank us for your reply
but the problem is, i want to check, when i start the Project and ui, if the panels (processobject, button, trendwindow) have no error
how check it by script
To check the syntax of panels you can use the '-syntax panels' option of the user interface. The manager always returns 0, so to get the number of syntax errors you need to read the 'PVSS_II.log' file or create your own external error handler (ExternErrHdl).
