I'm trying to get status for all managers in local host using this:
error=pmon_query(command,shostname,iport,result,ShowError,OpenTcp);
and it return an empty dyn_dyn_string ?
any help?
Pmon_query MGRLIST:STATI return empty
Re: Pmon_query MGRLIST:STATI return empty
What was the return value of the function (in your example stored in 'error')?
Was there an error written in the log file?
- AliBou
It returns True (for my error result)
and the log:
Module: _QuickTest_
Panel: C:\\Siemens\\Automation\\Wincc_OA_Projects\\Projects\\TestProject\\panels\\objects\\WinccOAServer.pnl [objects\\WinccOAServer.pnl]
Script: Initialize
Library: C:\\Siemens\\Automation\\Wincc_OA_Projects\\Projects\\TestProject\\scripts\\libs\\pn.ctl
Line: 465, tcpOpen, connect(:63000): No error (0)
WCCOAui1:["--------Error= TRUE----------------"]
WCCOAui1:[dyn_dyn_string 0 items
WCCOAui1:]
WCCOAui1:["*****************Pmon Stopped*******************"]
thank you in advance
and the log:
Module: _QuickTest_
Script: Initialize
WCCOAui1:]
It looks like you are using an empty string as the host parameter. Try it with 'localhost' or the actual hostname instead.
- AliBou
