Hi all,
As of version 3.15 P007, you should be able to preload panels in an embedded module with the function loadPanel. Subsequently you should be able to scroll, either with the scrollToPanel function or by swiping.
This works fine when I preload only 1 panel. When I try to preload multiple panels, for example one right and one below, then I can only scroll to the panel that was loaded last.
What am I doing wrong?
According to the help: "By calling the function PanelLoad() multiple times additional panels can be preloaded and stored within the system memory cache."
I want to preload multiple panels to have a faster/smoother user experience. I am using 3.15 P015 on Windows 10 64-bit.
Karel
