In such a configuration RDB is actively writing data into one Oracle Database. The data which has been written to the Database will then be forwarded to a second site. This is helpful for maintenance windows
and provides also redundancy on Oracle Database LEVEL.
The synchronization will be handled by an oracle scheduled job, which is running as per default every 3 minutes, and it's pushing the data to the 2nd Oracle Database over an exisiting DATABASE LINK (DBFWDLINK) which will be
installed automatically during synchronization setup.
Sometimes it is necessary to check if the synchronization is running fine within the Oracle Database.
Lets assume that you have an event group configured which holds all event data. So to check synchronization it is necessary to use the eventhistory view which holds the whole bunch of online available data in the database for this group.
Another important table is the STATUSFWD table which can be found in the RDB - Schema after synchronization setup. The contents of the table represents the to do list, which data has to be transferred to the 2nd Oracle Database.
STATUSFWD
BULK_ID,
SYS_ID,
GROUP_NAME,
STATUS,
STATUS_TIME,
FROM_TIME,
END_TIME
In the STATUSFWD you have the END_TIME column which tells you the last timestamp synchronized for the Archive Group.
The contents of the END_TIMEcolumn can be taken as a basic information for the time period to check. Time periods which need to be checked must be before the END_TIME column of the ARCHIVE_GROUP.
Be aware that you will get UTC Times as a result. So you have to keep the local UTC Offset in mind.
Synchronization can be checked for the whole archive group in a certain time period :
select
a."LocalCT",
d."RemoteCT"
from
(select
count(*) "LocalCT"
from
eventhistory b
where b.TS
between to_timestamp ('15.10.18 13:30:00:000000000','DD.MM.RRRR HH24:MI:SS:FF')
and to_timestamp ('15.10.2018 13:40:00:000000000','DD.MM.RRRR HH24:MI:SS:FF')
) a
, (select
count(*) "RemoteCT"
from evethistory@DBFWDLINK c
where c.TS
) d
/ Synchronization can be checked within a certain time period grouped by element_id
select a.element_id "LocalElement",
a."LocalCT",
d.Element_id "RemoteElement",
d."RemoteCT"
from
(select b.element_id,
count(*) "LocalCT"
from
eventhistory b
where b.TS
between to_timestamp ('15.10.18 13:30:00:000000000','DD.MM.RRRR HH24:MI:SS:FF') -- Starting Time Local
and to_timestamp ('15.10.2018 13:40:00:000000000','DD.MM.RRRR HH24:MI:SS:FF') -- Ending Time Local
group by b.element_id) a
, (select c.element_id
, count(*) "RemoteCT"
from
eventhistory@DBFWDLINK c
where c.TS
between to_timestamp ('15.10.18 13:30:00:000000000','DD.MM.RRRR HH24:MI:SS:FF') --Starting Time Remote
and to_timestamp ('15.10.2018 13:40:00:000000000','DD.MM.RRRR HH24:MI:SS:FF') - Ending Time Remote
group by
c.element_id) d
where a.element_id = d.element_id
order by a.element_id
/ Code: Select all
a."LocalCT",
d."RemoteCT"
from
count(*) "LocalCT"
from
eventhistory b
where b.TS
and element_id=123456789
from
where c.TS
and element_id = 123456789
group by
c.element_id) d
