Radio box item styling
ivan141
Post by ivan141 »
Hi there,
I need to style a radio box for use on dark backgrounds but there seems to be a problem.
The first item in the radiobox assumes the correct foreground color and font,
every following radio button item I add through code (or in the editor) seems to revert to the default color and font.
I had to resort to setting a stylesheet to the radiobox but I doubt this is proper way the radiobox should function.
schneebergera
Re: Radio box item styling
Post by schneebergera »
it seems that the font-type was changed since the radio box was created.
If you start the panel in quick-mode, the changes should be visible.
Please save and close the panel and open it again.
Which version is used?
best regards,
ivan141
Post by ivan141 »
I'm using 3.15 P011 at the moment. I've already tried the things you suggested but they did not work for me.
Nevertheless I've tried again and have to confirm that if I add multiple radio buttons and then reopen the panel,
the new items assume the correct font and color after reopening the panel.
But the problem is that I need a dynamic number of buttons in the panel I'm making and the problem still rears it's head
when I add new items to the radiobox while initializing.
