I have created a blank panel with a trend object in it, then used the panel within a tab object on a different panel. The following behavior is seen: when the user selects to open the ruler the close button does not work and the ruler panel stays open until another area on the trend is clicked.
The following error is seen in the log:
WCCOAui (9), 2018.10.08 11:05:08.492, PARAM,WARNING, 17, Requested panel does not exist, PanelArea::closePanel, _trendRulerPanel_TREND11
Is this behavior seen on the ETM systems?
Thanks,
Chris
Trend ruler close button
Re: Trend ruler close button
Are you using the standard trend ruler panel?
- chris@blue-catalyst.co.uk
Yes we are, we are using 3.15 patch 11.
Try it with the latest patch (P015).
The same problem persists with the latest patch in 3.15 (p015) and in 3.16 (p003).
- schneebergera
we have corrected the behavior. It is planned to release it with the upcoming patches (3.15 P017; 3.16 P006).
the trend ruler 'Close' button doesn't work when trend is opened within a tab-widget.
with best regards,
with best regards,
