I am trying to convert a value from PLC which is either 16 bit or 32 bit in to an floating point single precision value.
Are there any ready made function is available?
As of now I am planning to do the conversion manually ( using expressions) in control script. I have to store the converted value in a DP.
Are there any best way to do this?
Also are there any function available to convert from integer (both signed and unsigned) to a binary number?
Thanks,
Bala
Floating point conversion from 32bit or 16bit
- vbalan007
Re: Floating point conversion from 32bit or 16bit
There is no need to manually do the conversion. Just assign the address config to a float datapoint element.
