Hello!
I'm using pmon_query command to collect information about managers in my net.
I resolved all addresses on all machines (added in .config localAddress = "").
I'm use .ctl script for collection data on redundancy active machine.
Where it working, in console has errors, like:
WCCOActrl (3), 2018.09.27 02:44:03.891, CTRL, WARNING, 54, Unexpected state, diagnostics\\managersInfo.ctl Library: C:\\Siemens\\Automation\\WinCC_OA\\3.15\\scripts\\libs\\pmon.ctl
Line: 261, tcpOpen, connect(s2012a:4999): Host not found (11001)
WCCOActrl (3), 2018.09.27 02:44:06.203, CTRL, WARNING, 54, Unexpected state, diagnostics\\managersInfo.ctl Library: C:\\Siemens\\Automation\\WinCC_OA\\3.15\\scripts\\libs\\pmon.ctl
Line: 261, tcpOpen, connect(s2012b:4999): Host not found (11001)
I dont understand what is wrong.. ping command to all servers is good, net configuration has static addresses ipv4 and dns on ipv6.
Error: Host not found (11001)
Re: Error: Host not found (11001)
So the commands 'ping s2012a' & 'ping s2012b' do get a response?
Can you also connect to the pmon with telnet/webbrowser?
- v.yarymov
1. yes
2. yes. I connect to the pmon with webbrowser and got page with pmons remote management
- tobias_raab
Note sure if this is related but we're facing similar problems.
Using pmon querys as well to monitor / start / stop managers.
The project used the pmon port 15001 befor migrating it to v3.16.
Afterwards we changed the port to 14001 but the functions paGetProjHostPort(...)/paGetProjAttr(...) are still delivering 15001 instead of 14001 which is listed in the config and used by the system.
Could you check this as well?
Tobias
Tobias
