Excel-Report can\'t be configured
frankySie
Post by frankySie »
when following the WinCC OA help information to configure the Excel-report,
this error is displayed by Excel:
Is this problem caused by WinXP OS or Excel or WinCC OA?
Computer runs a WinXP 32 bit and Excel 2007 SP2.
buec
Re: Excel-Report can\'t be configured
Post by buec »
Try to register MSCOMCTL.OCX in cmd.exe.
C:\\Windows\\System32\\regsvr32 mscomctl.ocx
Best regards
Christoph
if the problem still occurs after registering the mscomctl.ocx-component you could run the attached VB-script.
The script checks if necessary components for the Excel-report are installed.
Please send the result and a detailled problem description to the official WinCC OA support.
Senior Support Specialist https://www.winccoa.com/fileadmin/image ... Env_31.zip
checkReportEnv_31.zip
(606 Bytes) Downloaded 261 times
frankySie
Post by frankySie »
please let me report the result directly here. It is unclear what email address to use. Please forward this report to your support. Thx.
check environment for PVSS Report
create object 'Forms.SpinButton.1' ... OK
create object 'Forms.ListBox.1' ... OK
create object 'Excel.Application' ... OK
create object 'MSComCtl2.DTPicker' ... OK
create object 'MSComctlLib.TabStrip' ... OK
create object 'ADODB.Connection' ... OK
create object 'SubTimer.CTimer' ... failed 429: Objekterstellung durch ActiveX-Komponente nicht möglich
create object 'PVSS00Com.ComManager' ... failed 429: Objekterstellung durch ActiveX-Komponente nicht möglich
how to reach the ETM Support is described at the following entry at the ETM Portal
Home --> FAQ --> General --> How can I reach the ETM Support?
Which information is required is described at
Home --> FAQ --> General --> Which information is necessary to open a service request for the WinCC OA support?
Please notice that the ETM Portal does not substitute the common WinCC OA support.
The output for the VB-script describes that 2 necessary components are not installed or registered.
tmalone
Post by tmalone »
There are new patches and batch files available for this solution. Please contact support for this solution.
Issue also exists for MaPara tools
WinCC OA x64 on x64 OS with Excel 32-bit.
Todd Malone
HMI CoC
