XmlRpc problem after update with new patch - WinCC OA 3.14
nedzad
Post by nedzad »
Yesterday I updated WinCC OA 3.14 with the newest patch (P021). Now I have another problem. Every script that is using XmlRpc to communicate with protocol adapters is now going to state 3, with the following warning message written in log:
WCCILpmon (1), 2018.09.27 11:44:16.767, SYS, WARNING, 36/pmon, Blocking Manager WCCOActrl(111) detected. No heartbeat since 30 seconds.
Sometimes, the script starts automatically some time later, with this message in log:
WCCILpmon (1), 2018.09.27 11:49:01.932, SYS, WARNING, 39/pmon, Manager WCCOActrl(111) is no longer blocking.
Sometimes all scripts return to normal function, but when I try to restart any of them, or start some other script, all of them go to state 3 again.
We did not have this situation before installation of P021 patch, and now we have no idea how to resolve this. Also, what I noticed is when I turn off project on one server, all scripts on the other server start normally. When I start the project again, those sctipts go to state 3.
Do you have any idea what could cause this problem?
Nedžad Agi?
Re: XmlRpc problem after update with new patch - WinCC OA 3.14
From which version did you update?
Are the projects connected to each other?
Do you use the xmlrpc client and/or server?
How many scripts are using xmlrpc?
Which encoding is your project using? And which encoding does the xmlrpc communication use?
Only the readme of P012 from 3.14 mentions a xmlrpc change.
The problem is already in analysis by the WinCC OA support team.
There is no need to discuss this topic also in the forum.
