I am quering some dps containing a dyn_string. I need only the dps with a particular value in their dyn_string.
I tried to use: WHERE '_original.._value' == "MySearch" Unfortunately does not work for dyn_strings.
I have tried IN statement with no positive result either,
Somebody can give me a hand with this?
Thank you in advance
SQL Query: WHERE IN
- kilianvp
Re: SQL Query: WHERE IN
yes try this
main()
dyn_dyn_anytype tab;
dpQuery("SELECT '_original.._value' FROM '*.**' WHERE '_original.._value' == \\"MySearch\\" ", tab);
DebugTN(tab);
}- WINOA
Thanks for your answer.
But I am afraid it is not working for me.
The dyn_string is in the following structure:
DPexample (DPEexample)
Folder1
dynString (PosibleValue1, PosibleValue2, PosibleValue3)
The query I tried is:
dpQuery("SELECT '_original.._value' "
"FROM '*.**'"
"WHERE _DPT = \\"DPEexample\\" AND '_original.._value' == \\"PosibleValue1\\" "
, tab);
The result is empty. I have also tried with *.*** but no result.
Folder1
"FROM '*.**'"
, tab);
- WINOA
Any idea what I am doing wrong?
In my tests the LIKE comparison works for a dyn variable. I have tested it for a dyn_int, probably it also works for strings.
The query string I have used is
SELECT '_online.._value' FROM '{_Connections.Ui.ManNums}' WHERE '_online.._value' LIKE "*3*"
