Migration of Library
paramesh1985
Post by paramesh1985 »
We have developed our own library in version 3.12 if i want to use that library for 3.15 or latest version.
How we have to migrate only library . Is there any help topics available in the standard wincc oa help file.
I am not able to find any chapter like that.
R.Parameshwaran
WINOA
Re: Migration of Library
Post by WINOA »
You can find some info below in regards of 3.11:
https://readthedocs.web.cern.ch/display ... 11+to+3.15
from the CERN guys.
I hope it helps
Regards
If a library is a CTRL library (scripts/libs) there is no need to do a migration.
The CTRL libraries created in an older version are compatible with a newer version.
When you are talking about a C++ library (CTRL extension) you have to recompile the library based on the WinCC OA version which will be used.
paramesh1985
If the library is own object library (like symbols and DPTs). In that case also there is no need migration.
R.Parameshwaran.
